Configures the TCP RSA Data Security, Inc. MD5 Message-Digest Algorithm secret password for a peer group and all neighbors of the peer group.
| peer-group-name | Specifies a peer group. |
| none | Specifies no password. |
| tcpPassword | Specifies a password. |
| encrypted | Specifies an encrypted string. |
N/A.
Changes made to the parameters of a peer group are applied to all neighbors in the peer group.
This command applies to the current VR or VRF context.
After you enter this command, the switch automatically disables and enables all neighbors in the peer group before the change takes effect.
The following command configures the password as Extreme for the peer group outer and its neighbors:
configure bgp peer-group outer password extreme
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
